No Images in Zabbix 1.8 under Debian Lenny
  • julsch
    • Sep 2011
    Hello Folks,
    I do have an old known problem with my Zabbix-Installation. I cant upload pictures and I cant see the default pictures in Maps.
    After installing Zabbix via apt-get I ran the images_mysql.sql over my MySql-Database, but nothing happend. After that I setted my database to utf-8 encoding, but still nothing changed.
    Can you help me? Help is greatly appreciated, I do have a presentation on Wendesday and I would like to show some network-maps
    Thank you for your help!
  • eskytthe
    • May 2011
    • 363
    If you are in a hurry you may use the zabbix Appliance:
    http://www.zabbix.com/forum/showthread.php?p=89355.
    Or here - with zabbix presention from qix:
    You can also find some maps here:
    http://www.zabbix.com/wiki/doc/screenshots
    /Erik
    • julsch
      • Sep 2011
      Virtual Appliance
      Thanks eskytthe for your quick help. Unfortunatly I cant use the virtual appliance.
      I had a look into the zabbix mysql database. In the table "images" were lots of BLOB entrys instead of pathnames to the pictures. Is that right?
      Does anyone had the same problem? I installed zabbix 1.8 on a Debian 5.0 Lenny via apt-get with backports. Works beatifully, except for the maps part which I need!
      But thanks a lot for your help guys!
      • julsch
        • Sep 2011
        Does anyone also has troubles with creating maps under zabbix 1.8 with Debian 5.0 ??
