Web Scenario Page Matching
  • Yello
    • Apr 2011
    • 309
    I have a web scenario that is failing because the page does not match. The pattern I'm using to check the page is:
    (Institute)\s(of)\s(Electrical)\s(and)\s(Electroni cs)\s(Engineers)
    When I copy the output of curl into notepad++ and check the page content against this expression the pattern matches (using regex helper). So can someone tell me why this is failing in the zabbix gui and how I might get it to work?
    Regards,
    David
  • Yello
    • Apr 2011
    • 309
    I've also tried escaping the brackets and that isn't helpign either.
    Will appreciate any help on this.
    Regards,
    David
