HOw do I make 1 switch depend on another
  • johnw230873
    • Aug 2010
    • 54
    I have a small network and with any network I have core and edge switches, with each switch I have multiple triggers which have warning and high triggers. For this to work I need to depend the warning triggers off the high trigers (so I never get 2 active triggers for the same event).
    Now that I have this set up it is a bit hard to set full depends between switches.
    Is there a way of fully depnding switches at a switch level and not a trigger level. e.g. if sw1 goes down don't report on anything on switch 2?
  • ghoz
    • May 2011
    • 204
    unfortunately, you have to setup the all the dependencies at the trigger level...
    you can use mass update to set a dependency on a single trigger, but if you want to fine grain the depedencies, that means a lot of point and click, or an sql/ API extraction of the relevant triggers, and use the api / zabcon to create the dependencies...
