connection problem between agent and server
  • 6-MarViN
    • Sep 2011
    • 13
    I have a zabbix server and GUI on localhost. the monitoring of my server works perfectly. However I have another machine i would like to monitor too. I've installed the agent on it and configured it according to the Manual. Unfortunatly I get this error in the logs:
    Get active checks error: cannot connect to [server_ip:server_port] [connection refused].
    I've been through this forum already looking for answers, however none of it helped. nearly all my settings are default except hostname, which i changed according to the name in the GUI, and Server, which has been changed to the ip of the machine my server is on.
    Could you help me plz?
  • Davidus
    • Dec 2010
    • 281
    Well first of all check your firewall settings if any
    ports 10051(zabbix server) and 10050(zabbix agent) should be open
    Also check your agent configurations (for linux) http://www.zabbix.com/documentation/.../zabbix_agentd
    • Superkikim
      • Sep 2011
      • 12
      I'm having the same trouble.
      required ports are open, I can connect with telnet on them, no problem. But I dont' get any data on the server, nor do I have a green Z icon. This icon is still gray.
      My situation is the following:
      Server:
      Ubuntu 10.10 Server
      Zabbix server installed through zabbix-server-mysql package. Version 1.8.2
      Zabbix agent installed through zabbix-agent package: Version 1.8.2
      Currently, only one remote server has the agent installed:
      Debian 5.0.8, kernel 2.6.26-2-686
      Zabbix agent installed through zabbix-agent package: Version 1.4.6
      Both hosts show the same behavior on the server (or no behavior at all for instance) I don't really know what to do next. It's quite frustrating.
      Any help is welcome.
      • 6-MarViN
        • Sep 2011
        • 13
        Actually it was a firewall problem. Thank you very much.
        • Superkikim
          • Sep 2011
          • 12
          well doesn't seem to be my case...
          Can you elaborate what the issue was and how you fixed it ? please ?
