:(:(How to Monitoring aix6.1
  • jerry2049
    • Sep 2011
    • 20
    Hi,Dear All
    who can tell me how to installed zabbix_agent on aix6.1
    Does must be installed for the AIX version of the client? who can give me the detailed steps?
    Thankyou;
    This is my step for intsall zabbix_agentd
    Client installation and configuration:
    ①Environment
    yum -y install gcc
    ②Download and decompression
    tar zxf zabbix-1.8.6.tar.gz
    ③Configure ZABBIX users
    useradd zabbix
    cd zabbix-1.8.6
    ④Compile and installzabbix
    ./configure --prefix=/usr/local/zabbix --enable-agent && \
    make && \
    make install
    ⑤zabbixService configuration* Service port definitions:
    Edit /etc/services,In the appended:
    cat >> /etc/services << "EOF"
    zabbix-agent 10050/tcp Zabbix Agent
    zabbix-agent 10050/udp Zabbix Agent
    EOF
    * Copy the configuration file:
    mkdir /etc/zabbix
    cp misc/conf/zabbix_agent.conf /etc/zabbix/
    cp misc/conf/zabbix_agentd.conf /etc/zabbix/
    * Modify the configuration file:
    vi /etc/zabbix/zabbix_agent.conf
    Server=192.168.168.100
    vi /etc/zabbix/zabbix_agentd.conf
    Hostname=client servername
    * installation scriptcp
    misc/init.d/fedora/core/zabbix_agentd /etc/init.d/
    chmod a+x /etc/init.d/zabbix_agentd
    * Modify /etc/init.d/zabbix_agentd :
    BASEDIR=/usr/local/zabbix
    FULLPATH=$BASEDIR/sbin/$BINARY_NAME
    * Add to startup service:
    chkconfig --add zabbix_agentd
    * start Zabbix Agentd
    /etc/init.d/zabbix_agentd start
    As a client, I used the 1.8.6 version is installed in Linux and windows, are all no problem.
    But I can't use this installed on aix6.1
    Pls help me, write a Detailed documentation
    Last edited by jerry2049; 14-09-2011, 08:56. Reason: http://www.aixchina.net/club/attachments/month_1109/1109091340831e78b94fdfbdcc.jpg
  • jerry2049
    • Sep 2011
    • 20
    who can help me
    when I use zabbix_agents_1.8.5.aix5300-08.powerpc to installed...
    exec(): 0509-036 Cannot load program ./zabbix_agentd because of the following errors:
    0509-150 Dependent module /usrbbiconv.a(libiconv.so.2) could not be loaded.
    0509-152 Member libiconv.so.2 is not found in archive
    • jerry2049
      • Sep 2011
      • 20
      How to installed a clinet, I meas zabbix_agentd to installed on aix6.1
      Pls teach me
      • jerry2049
        • Sep 2011
        • 20
        I am sorry my English so bad
        when I installed zabbix_agentd in aix6.1 and execute command
        make && \
        make install
        the warning is:
        configure: WARNING: libperfstat.h: present but cannot be compiled
        configure: WARNING: libperfstat.h: check for missing prerequisite headers?
        configure: WARNING: libperfstat.h: see the Autoconf doumentation
        configure: WARNING: libperfstat.h: section"present but cannot Be compiled"
        configure: WARNING: libperfstat.h: proceeding with the compiler's result
        I didn't download specifically for the AIX version of zabbix_agentd
        I just download this one
        wget http://prdownloads.sourceforge.net/z...ar.gz?download
        All of the zabbix_server and zabbix_agentd are all use it
        I think I also lack of which the installation package
        can u tell me what is the package
        • hirschnf
          • Jan 2010
          • 56
          ok, we will look at this thread:
          • jerry2049
            • Sep 2011
            • 20
            According to your method, I have succeeded
            thankyou sir
            • jerry2049
              • Sep 2011
              • 20
              How to monitor aix6.1
              Hello ,Everybody
              I have been successfully installed zabbix_agentd in aix6.1
              but now my zabbix cannot detect some monitoring points
              for example
              I want to monitor the AIX network condition
              Login on my zabbix server and run this command
              ./zabbix_get -s 192.168.2.11 -k net.if.out[eth0,bytes]
              ZBX_NOTSUPPORTED
              I in accordance with this method to do
              http://www.zabbix.com/wiki/howto/mon...xuserparameter
              To use them add them to the end of your /etc/zabbix/zabbix_agentd.conf and restart the zabbix_agentd
              but when I restart my zabbix_agentd and then the System display
              bash-3.2# /etc/init.d/zabbix_agentd restart
              kill: 23069030: 0403-003 The specified process does not exist.
              Pls help me....
              • irvined
                • Aug 2010
                • 16
                AIX ethernet port check
                Are you sure you are 'looking' at the correct interface?
                For example on one of my AIX LPARs I see:
                en0: flags=1e080863,480<UP,BROADCAST,NOTRAILERS,RUNNING ,SIMPLEX,MULTICAST,GROUPRT,64BIT,CHECKSUM_OFFLOAD( ACTIVE),CHAIN>
                inet 10.X.Y.Z netmask 0xffffff00 broadcast 10.X.Y.255
                tcp_sendspace 262144 tcp_recvspace 262144 rfc1323 1
                en1: flags=1e080863,480<UP,BROADCAST,NOTRAILERS,RUNNING ,SIMPLEX,MULTICAST,GROUPRT,64BIT,CHECKSUM_OFFLOAD( ACTIVE),CHAIN>
                inet 172.X.Y.Z netmask 0xffffff00 broadcast 172.X.Y.255
                lo0: flags=e08084b<UP,BROADCAST,LOOPBACK,RUNNING,SIMPLE X,MULTICAST,GROUPRT,64BIT>
                inet 127.0.0.1 netmask 0xff000000 broadcast 127.255.255.255
                inet6 ::1/0
                tcp_sendspace 131072 tcp_recvspace 131072 rfc1323 1
                So it may be you just need to change eth0 to en0
                Cheers,
                Doug
