a problem for install orabbix
  • jerry2049
    • Sep 2011
    • 20
    [root@zabbix template]# java -version
    java version "1.6.0_27"
    Java(TM) SE Runtime Environment (build 1.6.0_27-b07)
    Java HotSpot(TM) Client VM (build 20.2-b06, mixed mode, sharing)
    when I start my orabbix......
    [root@zabbix template]# /etc/init.d/orabbix start
    Starting Orabbix service:/opt/orabbix/run.sh: line 1: java: command not found
    [root@zabbix ~]# vi /opt/orabbix/run.sh
    java -Duser.language=en -Duser.country=US -Dlog4j.configuration=./conf/log4j.properties -cp $(for i in lib/*.jar ; do echo -n $i: ; done).:./orabbix-1.2.0.jar com.smartmarmot.orabbix.bootstrap start ./conf/config.props &
    where is the trouble??
  • Colttt
    • Mar 2009
    • 878
    hmm you can use the absolute-path..
    /usr/bin/java
    it maybe help
    Debian-User
    Sorry for my bad english
