Couple agentd error messages
  • gpearson
    • Mar 2006
    • 10
    I have solved one error message for the most part which was Timeout while answering request which I still get every once and awhile but my next one I am unable to solve is
    Error writing to socket [ Connection reset by peer]. This one looks like it only happens when it does
    check_service[ssh]
    Can anyone enlighten me on these 2 errors
  • mary nancy
    • Jul 2005
    • 125
    Hi
    Can you check this thread. I hope it might server your purpose
    Regards
    Nancy
    • gpearson
      • Mar 2006
      • 10
      Viewing the noted thread I am able to telnet to the remote machine and get the version number. I have found out that the Error writing to socket message is on every request to check SSH on the remote Linux Machine. I will do other searches to see if I can solve this message. The Timeout while answering request also happens on the ssh check.
      • mary nancy
        • Jul 2005
        • 125
        Which version of zabbix are you using?
        If your using beta2 and above, these parameters(check_service) are replaced by new parameters. Please try this parameter to monitor ssh
        net.tcp.service[service,ip,port] - Check if service server is running and accepting connections.
        these are the outputs from the parameter.
        0 - service server is down
        1 - service server is running
        Please check the beta manual for further detaisl
