zabbix_agent vs zabbix_agentd
  • yanick
    • Mar 2006
    Discovered Zabbix this week, and have the gleeful feeling my life will get much simplier from now on. :-)
    In the documentation, it is said that the use of zabbix_agentd is recommended over zabbix_agent. But I couldn't find further details anywhere on why that is. Is there a place where the pros and cons of both agent are given?
  • bbrendon
    • Sep 2005
    • 873
    I've been using zabbix since the early 1.1 alphas and honestly have no idea what you're talking about. you're probably reading something old that should be ignored.
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • yanick
      • Mar 2006
      Could indeed be a leftover of old documentation. I found it at http://www.zabbix.com/manual/v1.1/install_agent.php . Near the bottom of the page it is said:
      If you plan to use zabbix_agent instead of the recommended zabbix_agentd [..]
      • elkor
        • Jul 2005
        • 299
        zabbix_agent is intended to be spawned out of the inetd superservice on *nix boxes. This means that inetd would have to be enabled and that the agent itself would only be active and in memory when it was polled. This means there would be startup/shutdown overhead on each poll, no possibility of active checks, and the security concerns of inetd itself to take into consideration.
        • yanick
          • Mar 2006
          Gotcha. That's what I was thinking, but I was not necessarely seeing the agent being loaded only when prodded as a bad thing (and it probably isn't, as long as we're talking about a machine being monitored only once in a while rather than constantly).
          Thanks for the clarification!
