show link on maps
  • schul
    • Feb 2006
    show link on maps
    Hello everyone,
    I've seen screenshots where all machines are linked together on maps. I've been trying to do that on my computer but i can't create any connectors (sql error) i created one directly into the database but it doesn't show up on the map.
    How can i ceate links between devices ?
    I'm using 1.1beta7
    Regards,
    Schul
  • crs9
    • Feb 2006
    • 35
    I'm having a similar problem trying to create my maps, I get:
    SQL error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '18,12483,,'',4,'Red')' at line 1
    Query: insert into sysmaps_links (sysmapid,shostid1,shostid2,triggerid,drawtype_off ,color_off,drawtype_on,color_on) values (2,,18,12483,,'',4,'Red')
    Is this the error your getting Schul?
    • schul
      • Feb 2006
      yes it is !
      However even when i entered the data directly into the mysql database i still don't have anything showing on the maps ...
      Help !!
