Version 1.1 Item Issues
  • gpearson
    • Mar 2006
    • 10
    Running version 1.1Beta7 I have acouple of issues with the items section.
    1) With net.tcp.dns[ip,zone] what would the zone be. I have only enterd an IP address which is always returning a 0 to the server.
    2) In the Trigger Section how does one put the Host so when I goto Monitoring -> Triggers it shows the Host which has the problem. At the current time mine just show POP Server Down without the host
    3) Under Reports -> Zabbix Server is running mine shows No which it is currently running. What is needed to resolve this
    If I can get these issues resolved and understand this a bit more, I would be one user who would convert from nagios as this is much better in my opion than nagios is.
  • mary nancy
    • Jul 2005
    • 125
    Your trigger statement depends on the trigger name you better give your trigger name as Host.Win32 - POP Server is down.
    try restarting your zabbix server process by giving ./zabbix_server &
    (please issue this command in beta/bin directory) this might help you solving the 3rd issue
    Regards
    Nancy
