Can I modify DB structure?
  • dickinson
    • Oct 2010
    • 44
    Hi everyone again,
    I need to modify the datatype of a field in a table (httpstep) 'cause the string i want to storage is bigger (it has 2120 characters but the field only allows 817)
    My question is, in addition to perform a backup, is there any recommentation to do that?
    Tnx in advance...
  • dickinson
    • Oct 2010
    • 44
    Hi guys..any answer? plz help
    • nelsonab
      • Sep 2006
      • 1233
      I don't think changing the schema would fix your problem. In addition the Zabbix server has a fixed maximum length used for strings. I would need to look into the source code, but any change you make to the schema needs to correlate with a change in the source. A word of warning, there are a lot of moving parts and it is not recommended to make changes to the source unless you take the time to educate yourself first.
      RHCE, author of zbxapi
      • richlv
        • Oct 2005
        • 3112
        might be https://support.zabbix.com/browse/ZBX-4152
        • dickinson
          • Oct 2010
          • 44
          Ups..it's more complicated i thought. I'm gonna try to change our app insted. Thank you very much...
