Web alert delay
  • nicolasg
    • Apr 2011
    • 50
    Web alert delay
    Hi All,
    I have successful configure a web check trigger that checks the status of a health page every 60 seconds. When the healthcheck fails I receive an alert immediately, the trigger expression I have working is :
    {Web_Host:web.test.fail[Web_HTTP_Check_Scenario].last(0)}#0
    How can I extend the alert to be notified after 5 minutes that the health check have failed ? I have tried instead of last(0) to change it to last(5) as I thought this would mean 5x 60 seconds = 5 minutes but I keep receiving the alerts right away as as before.
    Regards,
    NG.
  • Ori0n
    • Dec 2010
    • 35
    Check the manual re: the last function. last(5) is equal to last(0). Try something like this instead:
    {Web_Host:web.test.fail[Web_HTTP_Check_Scenario].sum(300)}>0
    http://www.zabbix.com/documentation/...onfig/triggers
    Originally posted by nicolasg
    Hi All,
    Regards,
    NG.
    • nicolasg
      • Apr 2011
      • 50
      Hi Ori0n, thanks for the reply.
      Unfortunately the triggers functions seems to be working a little bit different for the Web check alerts...
      The expression
      .sum(300)}>0
      have a strange behavior, the alert is triggered right away when the problem occurs, when the problems is solved then the alert is cleared after 5 minutes ...
      Any ideas ?
