snmp traps receiver for cisco [again]
  • highland7
    • Sep 2011
    Hello
    I've tested zabbix 10 month ago. It was good product but had weak snmp trap subsystem. I have ~500 cisco devices sending snmp traps to my old NMS (HP open view nnm). Zabbix could not handle that easily.
    There was no mib management system, all needed to be done manually - configuring demons such as snmptrapd and snmptt, and in fact it did not worked.
    Here is link to my old post:
    The other problem was with map - it was not programmed. For example i could not change color of my router from green to red when the device lost network connection. Similar situation with link: i could not change link color when receiving snmp trap link down.
    1. Has anything changed in snmp trap subsystem ?
    2. Are there any improvements in map and actions changing colors ?
    3. Does anybody use zabbix with big cisco enterprise network and uses snmp traps subsytem for different trap types/different devices group ?
    (i need to program some uncommon trap like cisco ACE serverfarm down, and i lack functionality like "add/define this unknown trap which is received by zabbix)"
    Best regards,
    Michal Garcarz
