ESXi Servers behind Firewalls
  • NaZ
    • Oct 2011
    Hello
    I got a problem. I have to monitor ESXi Servers behind firewalls. Now i cant do it with CIM. right? (because my root server cant "find" the ESXi servers).
    now some/most of these servers run Microsofts SBS. i could easily install the agent on these virtual machines, and use active checks, but would the result make any sense?
    How would you monitor a ESXi machine behind a firewall?
    i would appreciate any kind of help.
    thx
    David
  • NaZ
    • Oct 2011
    Has nobody got an idea how i could solve my problem ?!
    • badener
      • Sep 2009
      • 42
      can't you put a proxy behind the firewall ? I am just starting to put proxies in networks with servers I couldn't monitor because the main zabbix server wasn't allowed to connect to them. Until now this looks like a good thing and my security guys are much happier with it as well.
      Yet - I don't know whether proxies can monitor using CIM ? Is that possible with zabbix at all ? I haven't tried monitoring esx servers as we use vcenter which has alerting.
      Monitoring from within a VM only makes sense if the VM has access to the mangement network of the esxi.
      • NaZ
        • Oct 2011
        how can i reach a proxy behind a firewall ? i would have to open up a port, which i am not allowed to do...
        sry, i am not that familiar with proxys.
        • badener
          • Sep 2009
          • 42
          yes, you would need a firewall rule allowing the zabbix server to communicate with the proxy - if that is not possible I am not sure you'll be able to monitor at all.
          My best idea is to discuss this with the firewall guys (at least that's what I would do in our company) - they know what's allowed and what's not
          • NaZ
            • Oct 2011
            well, then i can only do active check within the VMs. Thanks so far.
            • NaZ
              • Oct 2011
              ESXi 5.0
              but, by now i have worked around this problem by monitoring the vms. works for me. monitoring the esxi servers would of course be the best solution
              • jantanik@gmail.com
                • Feb 2012
                I am having the similar problem. Has anyone figured out a solution? I am looking forward to your response, thanks!
