Is this possibly with maps
  • johnw230873
    • Aug 2010
    • 54
    I have a map of our country and it is broken up into regions. What I would like to be able to do is colour code the different regions depending on if the trigger is a High, Average or Warning trigger. Like Red, Yellow, Orange and green.
    Where this comes arround is say I have a hard drive that has triggered a Warning as it is only 70% fill and NOT a High which is set at 90%
    Hence for warnings I don't want the highlighted regional to be Red as it is only a warning.
    The issue I'm finding is that maps etc only change their icons on problem, unknown, maintenance and disabled so it doesn't help me.
    Any ideas how to achive this?
  • Colttt
    • Mar 2009
    • 878
    hmm.. you can create "icons" of each country, after this you can join this together..
    now every country can be change the color
    Debian-User
    Sorry for my bad english
    • johnw230873
      • Aug 2010
      • 54
      my issue is that I don't know how to change the colour of an icon depending on if it is a warning or if it is a high error.
      • Colttt
        • Mar 2009
        • 878
        hmm ok.. you upload two different icons.. one for normal-status and one for error status, after this you can take a normal-state-icon and an error-state-icon..
        Debian-User
        • johnw230873
          • Aug 2010
          • 54
          Thanks for the reply shadow, this however will not work as a Warning and a High trigger are both problems so the same icon will show for both states.
          • Yello
            • Apr 2011
            • 309
            Use advanced icons.
            Regards,
            David
            • Colttt
              • Mar 2009
              • 878
              *PUSH*
              hello,
              i´ve an solution
              if you have >=zabbix1.8.3 look at this: http://www.zabbix.com/documentation/...p_improvements
              you can check this under map-options.. its quite hidden
              Debian-User
              • johnw230873
                • Aug 2010
                • 54
                Ta, at the end of the day I did something like this.
                On a clear map of the country I place a small grey dot in each region and used this map highlighing.
                Now the large circle arround the dot repersents the degree of the issue.
                now if I could only figure out why the queue keeps growing
