How to monitor the AIX LAN traffic
  • jerry2049
    • Sep 2011
    • 20
    Hi Guys
    My system is aix6.1 and I can monitor its CPU, memory and disk space
    but I can't monitor Host boot time and Traffic
    Notsupport by zabbix agentd
    who can help me?
    It is very import for me to finished it
  • irvined
    • Aug 2010
    • 16
    In my configuration I monitor a number of LPARs and dedicated servers.
    My template just looks at the en0 interface.
    If your systems have different device names then you won't be able to get data back from them.
    Check on the system you want to monitor for the name of the interface. If it's not en0 i.e. en1 then you will have to midify the item to look at the correct device.
    Hope this helps.
    Cheers,
    Doug
