Is there a simple trigger that actually work for IP availability?
  • xcalibur
    • Apr 2011
    • 40
    I simply would like to know wether or not my servers are online.
    Ping Check\unreachable for 3 minutes and what not keep spamming my mail with false results.
    Is there a simple syntax that work properly?
  • mazate
    • Oct 2011
    • 20
    I'm having exactly the same problem...
    • xcalibur
      • Apr 2011
      • 40
      Anyone?
      • Colttt
        • Mar 2009
        • 878
        yes you can use simplechecks.. icmpping
        Debian-User
        Sorry for my bad english
        • mazate
          • Oct 2011
          • 20
          Thanks, I'll try that...
          • HullZabbix
            • Feb 2011
            • 104
            We had problems when sometimes a machine wouldn't reply back to a ping ocassionally, but was actually online. So now for a trigger we use this:
            {Template1:icmpping[].last(0)}#1 | {Template1:icmpping[].nodata(120)}=1
            Admittedly last(0)#1 is probably a bit pointless as if the host is offline then it's not going to reply with anything. So if we get no reply for 120 seconds (the ping item is every 60 seconds)
            For remote servers where pings are even more unreliable we use the trigger with a ping item every 30 seconds:
            {Template2:icmpping[].avg(210)}<0.5 | {Template2:icmpping[].nodata(210)}=1
            • mazate
              • Oct 2011
              • 20
              Now I'm using icmpping with this expression,
              {Template_Windows:icmpping.count(300,0,"eq")}>3
              and it's working fine.
              • vrolok
                • Jan 2011
                • 22
                I'm trying to understand your trigger, can you tell how to "read" it. Thanks!
                • mazate
                  • Oct 2011
                  • 20
                  This is my understanding...
                  I set one simple check item, icmpping, to ping every minute (fping is required).
                  This expression counts the number of failed pings (status equals to "0") in the period of 5 minutes (300 seconds).
                  If it is grater than 3 (out of 5) then there is a problem.
                  Hope this helps.
                  • Davidus
                    • Dec 2010
                    • 281
                    Hello everyone,
                    Would like to share with you guys my solution for this particular issue. Because of the different circumstances I`m doing following (might be useful for someone, cause using this method we don’t need zabbix agent at all)
                    ITEM
                    Description: Exchange servers connectivity
                    Type: Zabbix trapper
                    Key: eserv.connect
                    Type of information: character
                    TRIGGER
                    Name: No connectivity to Exchange server
                    Expression: {EXSERV:eserv.connect.strlen(0)}#1
                    I have perl script, which is located at the same server where zabbix server is.
                    #!/usr/bin/perl
                    #following scripts monitors Exchange servers connectivity status;
                    	if( system(" ping -c 2 192.168.25.142 > /dev/null ") )
                    		system(' /usr/local/bin/zabbix_sender -z localhost -s " EXSERV " -k eserv.connect -o "Cannot PING Exchange server" > /dev/null ');
                    	else
                    		system(' /usr/local/bin/zabbix_sender -z localhost -s " EXSERV " -k eserv.connect -o "0" > /dev/null ');
                    exit;
                    This is it!! Link to this script I placed in cron and cron is running it once every 15 minutes
                    Regards
                    • mazate
                      • Oct 2011
                      • 20
                      Thanks for sharing...
                      • HullZabbix
                        • Feb 2011
                        • 104
                        Just incase you weren't aware, icmpping[] doesn't require a zabbix agent. So the script method above seems rather long winded.
