Unmounted disk alerts
  • robertomoraes
    • Nov 2008
    Hello all,
    I'm having some problems with disk monitoring, specifically if i unmount one partition to do checkdisk, the agent return the freespace from the upper directory '/', or weathever is one point up, i suppose that the agent uses 'df' to verify the free space, as the behavior is the same .. any suggestions on how to circumvent this problem ?
    Thanks in advance.
