Dependencies Hell
  • firque
    • Jun 2008
    • 32
    Dependencies Hell
    Guys, really i am fed up with it
    I used to have the trigger dependencies in seperate templates, if i attached that template to a host in a remote site it got the dependency for the router in that site automatically.
    Since a couple of versions ago it is impossible to add dependencies to a template. Does this really really really mean i have to add those dependencies to every single host??? I have about 1200 host to monitor and i don't have alot of spare time during the day.
    Really, this used to work perfect until a couple of versions ago. Can you please provide me with a decent solution. And maybe a reason why you taken this feature out. I can't imagine I am the only one complaining about this.
    Please for once, do not ignore me
    thanks
  • qix
    • Oct 2006
    • 423
    No, you're not the only one.
    See https://support.zabbix.com/browse/ZBXNEXT-835
    Vote on it if you want to see it implemented.
    In the mean while, you could perhaps use the API or a zabcon script to automate adding dependencies to your host triggers.
    IMHO that would be the best solution for now.
    With kind regards,
    Raymond
