simple question about items
  • alberte
    • Oct 2011
    • 18
    i am very new to this...
    my question is this.
    i see that the templates have multiple items associated with each application. most of them dont have triggers. i understand the purpose of triggers...
    i dont see any place that shows you the results for the "items" except for the graphs...
    can someone enlighten me and tell me how to work with items? i know what they are used for but i dont know how to check on the results after the device is polled.
  • alberte
    • Oct 2011
    • 18
    found one place
    ok, monitoring, latest data seems to have the info that i am looking for.
    any additional details would be appreciated. thanks
    • alberte
      • Oct 2011
      • 18
      overview tab has all the info i am looking for. sorry about the noob question
      • arikin
        • Aug 2011
        • 27
        Latest data
        If the Host's item has been polled then it should show up under:
        Monitoring -> Latest data
        This is a list of the items currently being monitored, grouped by Host.
        Click on the plus sign next to the Host that has the item you are interested in.
        If you click on the Graph link to the far right of the item you will get the graph for the polled data. There is a pull down menu on the right above the graph. If you select Values it will give you the actual data used for the graph.
        Note:
        - Host not listed: The monitoring for the host/item is disabled or... make sure Group and Host pull-down menus at the top right are not limiting what is shown (try "all" for both).
        • alberte
          • Oct 2011
          • 18
          thanks
          thanks for the help arikin.
