zabbix start stop
  • tx4real
    • Mar 2006
    zabbix start stop
    Greetings:
    OK, I can start zabbix with ./zabbix_server, but how do
    I stop and/or refresh zabbix ?
    i.e.
    Is there a zabbix start|stop|refresh option that I'm missing ?
    Thanks,
    JZB
  • crs9
    • Feb 2006
    • 35
    You can either put in a system startup script or create an init file for it and make it a service. I run fedora/ red hat systems and someone on the forums had an init script already made. There are a few different distros already made for download. Just search on startup script
    • tx4real
      • Mar 2006
      RE: Zabbix start stop
      Thanks ... I will do the search on startup script.
      • krusty
        • Oct 2005
        • 222
        Watch the directory /.../zabbix/misc/init.d/<your distribution>/
        There you will find the start | stop | restart scripts. But make sure that you have changed the path into the script.
        • Padawan.AVT
          • May 2009
          • 26
          And how to do the same on Solaris 10?
          • untergeek
            • Jun 2009
            • 512
            Tweak this however you need. This is what I use and put in /etc/init.d/zabbix_server
            #!/sbin/sh
            # Donated code that was put under PD license.
            umask 022
            CAT=/usr/bin/cat
            KILL=/usr/bin/kill
            SU_USER=zabbix
            ZABBIX_SERVER=/usr/local/sbin/zabbix_server
            PIDFILE=/var/tmp/zabbix_server.pid
            stop_service() {
                if [  -r $PIDFILE  -a  ! -z ${PIDFILE}  ]; then
                    PID=`${CAT} ${PIDFILE}`
                fi
                if [  ${PID:=0} -gt 1 -a  ! "X$PID" = "X "  ]; then
                    ${KILL} ${PID}
                else
                    echo "Unable to read PID file $PIDFILE"
                fi
            start_service() {
                # XXX We really should check if the service is already going, but
                # XXX we will opt out at this time.
                # Start zabbix_server
                echo "starting $ZABBIX_SERVER... \c"         ;
                su ${SU_USER} -c ${ZABBIX_SERVER}
                zabbix_rc=$?
                if [ $zabbix_rc -ne 0 ]; then
                    echo "$0: Error ${zabbix_rc} starting ${ZABBIX_SERVER}... bailing."
                    exit $zabbix_rc
                fi
                echo done.
            case $1 in
            'start')
                start_service
            'stop')
                stop_service
            'restart')
                stop_service
                /usr/bin/sleep 5 && \
                start_service
                echo "$0:  usage:  $0 {start|stop|restart}"
            esac
            • Padawan.AVT
              • May 2009
              • 26
              Well, I've already wrote pretty much the same script which in the end just kills the process. I thought there might be a way to tell process to shut down by itself with proper internal exit procedures (like softly close all handles, sessions and so on)
