Zabbix API and Values
  • tuo
    • Feb 2010
    • 18
    Heyho Zabbix community,
    maybe a simple question, but I can't find it in the docs.
    How can I send an item-value to the server via the Zabbix API? I am able to create hosts, groups, everything...but I can't find a way to now actually send the values via the API.
    I may use the zabbix_sender, but have problems with it not working correctly with hosts with blanks in their names and with the fact that I can't supply a DNS name.
    any help is greatly appreciated
    best regards
    tuo
  • nelsonab
    • Sep 2006
    • 1233
    You can't send item data via the API. The API is only for configuring Zabbix.
    If you need to send a value to Zabbix use the Zabbix Sender.
    RHCE, author of zbxapi
    • tuo
      • Feb 2010
      • 18
      The problem I am facing is that when I use Zabbix Sender, I cannot get it to work with host names with blanks in their names, and the second problem is that I cannot use it identify the host via it's DNS name.
      In our environment, we allow users to change the name of the hosts, as this is a needed feature. Thus, if the user changes the name of a host, the sending host send with a wrong hostname, so the data gets dropped.
      Which solutions exist for my problem?
      best regards and thank you for any and all help provided
      tuo
      • nelsonab
        • Sep 2006
        • 1233
        Have you tried putting the host name in quotes on the command line?
        You can change host names via the api.
        • tuo
          • Feb 2010
          • 18
          Yes, tried it with and without quotes, both without success.
          Changing the host name via the api would kinda lead to a cat and mouse game with the user changing it back. Of course I could cache the name the user entered, change it to something without blanks, send the data, and change the name back...but I would prefer a cleaner solution.
          best regards
          tuo
          • Tulkis
            • Feb 2019
            Is this still valid?
            Actually is not possible update trapper items with api?
            Thanks.
