Clearing Oracle database
  • gloover79
    • Nov 2009
    • 11
    Hi all,
    I'm running Zabbix 1.8.8 with an Oracle 11g R2 backend.
    After removing all hosts and importing their new xml files again, I found several hosts got wrong triggers which aren't in their xml configuration.
    These wrong triggers were old or demo triggers which already have been removed, but still can be found in the database.
    Is this a known issue and is there a solution for this?
    I removed all hosts from Zabbix now and want to cleanup the entire database to get a fresh start, but keep the current settings, so only removing old items, triggers, history etc.
    Does anyone know which tables can or can not be cleaned?
    And do I need to update the ids table to reflect these changes?
    Thanks.
