execute "remote command" in recovery message
  • fjrial
    • Feb 2010
    • 140
    Hi:
    I've setup an action with enable scalations, which only fires a remote command, and condition "trigger value" = "PROBLEM"..
    Action has enable "recovery message", because I want to receive the same remote command on recovery..
    Tested, but only executes remote command on problem status, it does nothing when trigger recoveries..
    Is there a way to achieve this behaviour.
    Thanks in advance.
  • fjrial
    • Feb 2010
    • 140
    replying to myself:
    to make it work, disable "recovery message", and setup both conditions:
    TRIGGER VALUE = "OK" && TRIGGER VALUE ="PROBLEM"
    • Kryol
      • Feb 2011
      • 70
      But how to receive another remote command on recovery?
