Hi Guys
I have a bit of an issue I'm trying to solve (and you're talking to an absolute Zabbix newb)
I have a load of EC2 nodes that spin up and down and I want them to register themselves automatically with my Zabbix server that runs outside of the EC2 world.
The problem with this is that it appears the Zabbix agent is using my EC2 internal IP, which is invisible to the outside world.
So in my logs I see a lot of:
28684:20111021:155524.478 Sending list of active checks to [176.xxx.xxx.xxx] failed: host [puppet] not found
28696:20111021:155524.953 Item [example:agent.ping] error: Get value from agent failed: *** Cannot connect to [10.xxx.xxx.xxx]:10050 [Interrupted system call]
Type of things. My IP is 176.x so I know that the top line is correct, but then Zabbix is trying to connect back on the 10.x internal ip which it will never be able to hit.
I tried setting the SourceIP address and it makes no difference.
If there anything I can do to bridge the gap or do I have to run a Zabbix proxy or something to make this work?
Tom
Tom
