Hi there,
I have a Sensatronics Senturion Temperature monitoring device which at times can be a touch flaky on SNMP checks.
Long story short when the unit is under stress or for whatever reason, the unit returns very very low values for temperature (and other sensors) these are like -400 degrees centigrade which is obviously false. Is there a way to specify to ignore these spurious results. For example i would expect the server room temperature to be between 0 and 100 not -400.
Any help would be appreciated. I couldn't see anything in the documentation to aid in this.
