is it possible to connect the agent w/ a php page fex. display cpu load?
get agent load data into php page
Well, you can connect to the agent eg. with "telnet <host> 10050", type in a item key and <return> then you will get the value of the item.
Or look here:
http://www.zabbix.com/documentation/1.8/protocols/agent
Hope this will help you.
Br
Erik
