Jboss monitoring - problem
  • vap007
    • Oct 2011
    Hi, I just get to the forum and I have a major problem. I am setting up zabbix to monitor jboss 1.8.8. In the server.log I have the following message:
    21982:20111026:002755.883 Item [Demeter:Classes_Loaded] became not supported: Type of received value [## A fatal error has been detected by the Java Runtime Environment:## java.lang.OutOfMemoryError: Cannot Type of received value [## A fatal error has been detected by the Java Runtime Environment:## java.lang.OutOfMemoryError: Cannot Type of received value [## A fatal error has been detected by the Java Runtime Environment:## java.lang.OutOfMemoryError: Cannot Not supported by Zabbix Agent
    21982:20111026:002755.884 Item [Demeter:Classes_Total] became not supported: Type of received value [## A fatal error has been detected by the Java Runtime Environment:## java.lang.OutOfMemoryError: Cannot Type of received value [## A fatal error has been detected by the Java Runtime Environment:## java.lang.OutOfMemoryError: Cannot Not supported by Zabbix Agent
    21982:20111026:002755.884 Item [Demeter:Classes_Unloaded] became not supported: Type of received value [## A fatal error has been detected by the Java Runtime Environment:## java.lang.OutOfMemoryError: Cannot Not supported by Zabbix Agent
    21982:20111026:002755.884 Item [Demeteraemon_Threads] became not supported: Not supported by Zabbix Agent
    21982:20111026:002755.884 Item [Demeter:Heap_Committed] became not supported: Type of received value [## A fatal error has been detected by the Java Runtime Environment:## java.lang.OutOfMemoryError: Cannot
    21980:20111026:002800.891 Item [Demeter:Perm_Gen_Init] became not supported: Type of received value [## A fatal error has been detected by the Java Runtime Environment:## java.lang.OutOfMemoryError: Cannot Type of received value [## A fatal error has been detected by the Java Runtime Environment:## java.lang.OutOfMemoryError: Cannot Type of received value [## A fatal error has been detected by the Java Runtime Environment:## java.lang.OutOfMemoryError: Cannot Type of received value [## A fatal error has been detected by the Java Runtime Environment:## java.lang.OutOfMemoryError: Cannot
    It is the only error message that I have and not what is the problem.
    Thank you very much for your help.
