Could not load map image in zabbix Map
  • mastraze
    • Jul 2011
    • 30
    am using zabbix 1.8. I added an image as follows:
    Administration-->General and then create a new image.
    I choose a simple one from openstreet.org. But when creation the map, and browsing the image just we have added i doesn't appear.
    Any idea.. ? thanks in advance
  • richlv
    • Oct 2005
    • 3112
    do you see the image in the background dropdown ?
    if yes, it is likely your encoding on the database/tables is incorrect - it must be utf8. convert them to utf8 and reupload image.
    • mastraze
      • Jul 2011
      • 30
      Thanks for response,
      I see the image in the list. But i wonder how to change its format utf8 in the database. I mean if there is a specific table for the image to upload..
      • richlv
        • Oct 2005
        • 3112
        if you go to administration -> general -> images and switch to backgrounds, is the image displayed correctly ?
        • mastraze
          • Jul 2011
          • 30
          The image is added in list but not displayed..
          • Davidus
            • Dec 2010
            • 281
            do you see your picture in following dropdown?
            • skarllot
              • Oct 2011
              • 21
              Please paste the output to the following SQL:
              SHOW CREATE TABLE `zabbix`.`images`;
              • mastraze
                • Jul 2011
                • 30
                Thanks for reply,
                I see the image in the drop list but not displayed after creating my new map.
                I passed the command and it gives
                | images | CREATE TABLE `images` (
                `imageid` bigint(20) unsigned NOT NULL DEFAULT '0',
                `imagetype` int(11) NOT NULL DEFAULT '0',
                `name` varchar(64) NOT NULL DEFAULT '0',
                `image` longblob NOT NULL,
                PRIMARY KEY (`imageid`),
                KEY `images_1` (`imagetype`,`name`)
                ) ENGINE=InnoDB DEFAULT CHARSET=latin1
                i dont see the problem given from uploading the image...THX for help
                • richlv
                  • Oct 2005
                  • 3112
                  run mysql against zabbix database. then :
                  ALTER DATABASE CHARACTER SET utf8;
                  ALTER TABLE images CONVERT TO CHARACTER SET utf8 COLLATE utf8_general_ci;
                  that should be the minimum to get you going, although i'd strongly suggest converting all the tables, just in case.
                  after that, reupload all the broken images
                  • maruscya
                    • Jul 2007
                    • 129
                    Yeahhhh !!! Fix my problem
                    Many thanks !
