Hello everyone,
I'm quite new to Zabbix. I want to generate a report to get the total bandwidth usage for a snmp enabled host for the entire month. If anyone can help me with that I will be very thankful.
Pls advise me on this.
I'm using zabbix version 1.8 and the snmp device I'm trying to monitor is a router.
I’m using the snmp OID 1.3.6.1.2.1.2.2.1.10.23 with “ifInOctets23” as the key to get the inbound bandwidth. And I’m using the same OID with “ifOutOctets23” as the key to get the outbound bandwidth.
What I want to do is to get the total bandwidth usage report for a month for this Router. I wouldn’t mind writing a script to get it from the database. I want instructions to get the monthly reports step by step as I’m quite new to zabbix and network monitoring.
I have created seperate graphs for inbound and outbound bandwidth usage. But I do not know how to export the graphs or how to access the backend (DB) to retrieve the stats so that I can generate the graphs using a php script at-least.
I have attached a screen-shot of one graph I've got.
I would be very grateful if anyone could assist me with this.
Thanks a lot,
Thanks a lot,
