Simulating Mouse Click For web Synthetic Transaction
  • girishkg
    • Aug 2011
    • 11
    Its web monitoring section is monitoring 79 web services of our corporate network on different geo locations across the globe,, each of 6 scenarios (Steps - First Page, Login, Search, Check, Logout, Logout Check), drawing nice graphs. Triggers are just unbelievable to go with.
    Here is my requirement:
    1) I want to simulate mouse clicks on Synthetic Txn instead of URL based Txn
    Reason: All 79 Websites are jsp based and mostly many inside url will not be available as the script runs on server.
    Ex-1: To check items after login require a mouse click, which is not referred by a link
    Ex-2: Right click is required to get some items to choose which are not available through direct link
    Ex-3: Should be able to click on Search result
    2) What Macros have to be posted on web scenarios? Is there any manual or wiki on all available macros?
    I am already set with zabbix with amazing customized graphs/screens and dashboards, so I won't mind spending some time to work with macros.
    Can you please guide me on this with an example if possible?!!
    Girish KG
  • richlv
    • Oct 2005
    • 3112
    clicking on elements in page is not supported currently (as libcurl doesn't support such things). i'd also argue that right click in web pages/applications is a bad design
    you might be able to integrate with something like selenium, but that definitely won't be trivial
    • girishkg
      • Aug 2011
      • 11
      Re:Simulating Mouse Click For web Synthetic Transaction
      Is there any way of working with JSP pages where direct URL are not available?
      For example, I can login with direct POST, but not able to "Logout" by just simulating/posting "{logout}=Logout&enter=Enter" as "Logout" button is not available to call directly.
      Ex-2: I can call "Logout" from zabbix with a link "http://10.11.100.36/index.php?reconnect=1" but not the same on some JSP pages which doesn't give urls as such.
      Any help/work around/suggestion would be helpful for me here. My intension is to simulate Synthetic Txn on JSP sites similar to user.
      Thanks for your valuable time.
      • richlv
        • Oct 2005
        • 3112
        some users have implemented that as external scripts, but that won't be available in the built-in web monitoring views
        • girishkg
          • Aug 2011
          • 11
          Thanks for your time again..
          I will be waiting to hear from the users who have implemented it...Thanks
          • girishkg
            • Aug 2011
            • 11
            Have anyone implemented this type of synthetic txn to JSP pages?
            I am still waiting to see a light on this way. Thanks.
            • danrog
              • Sep 2009
              • 164
              I have done this using webinject...its a perl module and/or script...(they provide a working script but it uses their own perl module, so you could write your own if you wanted). I only did this because some of our web apps include an auth ticket in the query string that is used only on the first HTTP GET and since Zabbix does not currently support grabbing values and using them on subsequent requests I was stuck building something.
              I had a working setup using Selenium but it wasn't very reliable (not sure why, it think there were many factors involved, but I didn't really care about using actual mouse clicks to drive the app so I moved on - I might revisit it one day).
              Webinject. Contribute to sni/Webinject development by creating an account on GitHub.
              I used the nagios.pm notification plugin as a base and changed it to use zabbix_sender...
              Zabbix.pm
              PHP Code:
                          for my $file (@{$webinject->{'result'}->{'files'}}) {
                              for
              my $case (@{$file->{'cases'}}) {
              my $warn   = $case->{'warning'}  || 0;
              my $crit   = $case->{'critical'} || 0;
              my $label  = $case->{'label'}    || 'CASE'.$case->{'id'};
              $perfdata .= ' '.$label.'='.$case->{'latency'}.';'.$warn.';'.$crit.';0;0';
              $lastid = $case->{'id'};
              my $sendercli = "/home/zabbix/sbin/zabbix_sender -z btcboszab01.btci.com -s $webinject->{'config'}->{baseurl} -k web.syn.test[$label] -o $case->{'latency'} 2>&1";
              my $sender = `/home/zabbix/sbin/zabbix_sender -z btcboszab01.btci.com -s $webinject->{'config'}->{baseurl} -k web.syn.test[$label] -o $case->{'latency'} 2>&1`;
                              print
              $sendercli."\n".$sender."\n";
              The down fall of this is you have to build items manually on each website you want that corresponds to each of the test case labels in the webcheck script.
              Here is a sample of a web check...
              app-config.xml:
              PHP Code:
              <testcasefile>/home/zabbix/httptests/app/app.xml</testcasefile>
              globalhttplog>onfail</globalhttplog>
              reporttype>external:/home/zabbix/httptests/Zabbix.pm</reporttype>
              baseurl>app.domain.com</baseurl>
              break_on_errors>1</break_on_errors>
              output_dir>/home/zabbix/httptests/logs/app/</output_dir>
              Using firebug or an equivelent tool, you should be able to get all the proper POST/GET fields and URLs to build a test case.
              app.xml:
              PHP Code:
              <testcases repeat="1">
              testvar varname="URL">http://app.domain.com</testvar>
              <testvar varname="LOGIN">user</testvar>
              testvar varname="PASSWD">pass</testvar>
              testvar varname="NUMBER">xxxxxxxx</testvar>
              testvar varname="ACCOUNT">xxxxxx</testvar>
              testvar varname="SERVICE">xxxxx</testvar>
              testvar varname="PASSCODE">xxxxxx</testvar>
              <case
              id="1"
              description1="App Login"
              label="App_Login"
              method="post"
              url="${URL}/cas/login?service=${URL}/app"
              postbody="username=${LOGIN}&password=${PASSWD}&service=${URL}/app"
              logrequest="no"
              logresponse="no"
              sleep="1"
              parseresponse='ticket=|"'
              <case
              id="2"
              label="App_Home_Page"
              description1="App Home Page"
              method="get"
              url="${URL}/app/?ticket={PARSEDRESULT}"
              logrequest="no"
              logresponse="no"
              verifypositive="Search"
              <case
              id="3"
              label="App_Contact_Search"
              description1="App Contact Search"
              method="post"
              url="${URL}/app/ws/person/query"
              postbody='{"type":"STANDARD", "resultList":[],  "totalResults":0}'
              addheader="Content-Type: application/json"
              logrequest="no"
              logresponse="no"
              sleep="1"
              verifypositive="${NUMBER}"
              <case
              id="4"
              label="App_Contact_Details"
              description1="App Contact Details"
              method="post"
              url="${URL}/app/contact/load.initialize?action=VIEW&cid=14831"
              logrequest="no"
              logresponse="no"
              sleep="1"
              verifypositive="${ACCOUNT}"
              <case
              id="5"
              label="App_Contact_Services"
              description1="App Contact Services"
              method="get"
              url="${URL}/app/meeting/listContactServices.initialize"
              logrequest="no"
              logresponse="no"
              sleep="1"
              verifypositive="${SERVICE}"
              <case
              id="6"
              label="App_Details"
              description1="App Details"
              method="post"
              url="${URL}/app/meeting/listContactServices.process"
              postbody="_CHECKBOXES=&meetingType=xxxxx"
              logrequest="no"
              logresponse="no"
              sleep="1"
              verifypositive="${PASSCODE}"
              <case
              id="7"
              label="App_Logout"
              description1="App Logout"
              method="get"
              url="${URL}/cas/logout?service=${URL}/app"
              logrequest="no"
              logresponse="no"
              sleep="1"
              verifypositive="Login"
              testcases>
              You would then run via cron...
              # Webinject HTTP Tests
              */5 * * * * zabbix perl /usr/bin/webinject.pl -c /home/zabbix/httptests/app/app-config.xml >/dev/null 2>&1
