monitoring web - values not displayed
  • Filter
    we are monitoring web services via standard zabbix built-in procedure (Monitoring -> Web). everything is fine except that regular user can not see values from the graph (response time for example). graph is displayed but when you click on Values, blank page is displayed. when i give this regular user super admin rights, it's ok. what has to be changed in order to see numeric values?
    nobody?
      are you sure that you are doing everything right?
        i hope i'm doing everything right.
        here are 4 screenshots describing the same procedure, first two with user "admin", last two with a regular user "test".
          wired... have no idea what possibly can be the source of following issue. sorry
            Can you show how you have permissions set up for this user?
            Regards,
            David
              it doesn't matter which group he is in, even the "Zabbix administrators" group where the Admin is doesn't seem to work.
              only thing that works is to change the user type to "Zabbix Super Admin". "Zabbix Admin" is still not enough.
                Yes, that doesn't look right. Do you see this repeated across multiple hosts? If so, I suggest you report it as a bug.
                Regards,
                David
                  yes, the same behaviour on both monitored web servers
                    confirmed as bug
                    https://support.zabbix.com/browse/ZBX-4348
                    Announcement
                    No announcement yet.
