I'm trying to capture SNMP Traps from Avaya G450 and am running into an issue. I'm using the snmptrap.pl script from the Wiki(a new solution) and have everything working great except for traps getting truncated. Any idea why?
#whats being stored in Zabbix DB
G3-AVAYA-TRAP::alarmMajor, g3clientExternalName: "CM6", g3alarmsProductID: "1000000000", g3alarmsAlarmNumber: "FPA:00000:1108130503:0000000000::N", g3alarmsPort: "A:\2011-11-08
#What I'm sending to Zabbix DB using zabbix_sender
/usr/local/bin/zabbix_sender -z localhost -p 10051 -s "TTC - S8300D_G450" -k snmp_traps -o "G3-AVAYA-TRAP::alarmMajor, g3clientExternalName: \"CM6\", g3alarmsProductID: \"1000000000\", g3alarmsAlarmNumber: \"FPA:00000:1108130503:0000000000::N\", g3alarmsPort: \"A:\\"2011-11-08 13:05:03 172.xx.xx.xxx\(via UDP: [172.xx.xx.xxx]:161\) TRAP, SNMP v1, community public#012#011avEntPhyChFruNotifications Enterprise Specific Trap \(avEntPhyChFruPsuFlt\) Uptime: 14 days, 22:03:21.50#012#011avEntPhysicalIndex.0 = INTEGER: 53#011entPhysicalDescr.0 = STRING: G450 Power Supply 400W#011avEntPhyProductId.0 = STRING: 7000090841#011avEntPhySeverity.0 = INTEGER: critical\(3\)#011avEntPhyChFruOperStat.0 = INTEGER: fault\(2\)#011avEntPhyChFruFault.0 = INTEGER: malfunctionAndAcFault\(4\)\\"\", g3alarmsMaintName: \"GW_ENV\", g3alarmsOnBrd: \"10\", g3alarmsAlarmType: \"MAJ\", g3alarmsIPAddress: \"172.xx.xx.xxx\", g3alarmsCategory: \"\", g3alarmsErrorCodes: \"\""
