read permissions on groups
  • nightwish
    • Dec 2010
    • 25
    Hi Gurus.
    I have 3 installations of zabbix and none of them do what I need.
    All the installations in the same version zabbix 1.8.4.
    Install zabbix from the beggining, all works fine.
    Create a test user ( type zabbix admin ), assign the user to a group.
    Give permissions to that group to have read access to template or hosts.
    Login qith the test user, and I cannot see any template hosts or host group as read only.
    Anyone can point the right direction.
    It must be something that I am doing rong ?
    regards.
  • safpsr
    • Aug 2007
    • 70
    I have the same behavior with V2.0.3 But I can add this template to a host ...
    It seems that the read option autorize the linking of a template to a host but not the possibility to viewing it
