can I use zabbix for security configuration check in centos
  • perlish
    • Nov 2011
    hi all,can I use zabbix for security configuration check in centos ?
    1.check the kernel version whether great than 2.8.18.237-1 or not.
    2.check the glibc,systemtap and udev version whether great than secure
    version or not.
    3.check the php.ini whether set safe_mode to on or not.
    4.check the sshd_config whether set PermitRootLogin to no or not.
    If zabbix can make it ,would you like to be kind enough to tell me
    which class I should use? or which keyword I should search for.
    Thank you very much !
