standalone to distributed node
  • vapolise
    • Nov 2011
    hi,
    can i migrate existing production standalone to distributed node environment.
    regards
    Vamsi
  • getUP
    • Jun 2006
    • 34
    Yea, stop Zabbix, run:
    ./zabbix_server -n 1 -c /etc/zabbix/zabbix_server.conf
    And start Zabbix again.
    Make sure you replace 1 with the NodeID from zabbix_server.conf.
    • Axilla
      • Aug 2010
      • 130
      make sure you execute that command above with care and make sure you backup your databases before hand.. Once you do it there is NO GOING BACK... Make sure you have the proper nodeid and such.. good luck
