Using grpsum in a calculation
  • nleaman
    • May 2010
    • 35
    How do I go about creating a calculated item that references aggregate items
    For example, to create a calculated item whose result is all mail storage utilization (%) for all hosts in the "Mail Storage Hosts" hostgroup, this is what I tried:
    100*last("grpsum["Mail Storage Hosts","mail.storage.used","last","0"]")/last("grpsum["Mail Storage Hosts","mail.storage.total","last","0"]")
    ...but it doesn't like that syntax. The goal is to only use hostgroups to specify hosts, and not hardcode host names into the calculation.
    I feel like I am just missing something obvious.
  • Tractorboy
    • Oct 2010
    • 98
    A few things to try
    Try
    and
    on there own first
    if they are ok then go
    100 * grpsum["Mail Storage Hosts","mail.storage.used","last","0"] / grpsum["Mail Storage Hosts","mail.storage.total","last","0"]
    and see what happens
    • nleaman
      • May 2010
      • 35
      Originally posted by Tractorboy
      Try
      and
      on there own first
      Doesn't seem to work:
      26350:20111128:161404.095 Item [Mail Storage:mail.storage.global.utilization] became not supported: Format error or unsupported operator. Exp: [grpsum["MailStorageHosts","mail.storage.used","last","0"]]
      The Zabbix aggregate it's referring to works fine and has plenty of values. It doesn't seem like grpsum[] can be used in a calc item.
      • Tractorboy
        • Oct 2010
        • 98
        GrpSum
        I do not have any issues with grpsum, so is the format of your key possibly the issue? I am assuming you are storing numeric data?
        I assume this calculated item is being stored in the database?
        I'd like to have someone input further on this as it does seem strange.
        • nleaman
          • May 2010
          • 35
          Yes it is all numeric data. The calculated item is not being stored in the database... the aggregated value is and I'm trying to create a calculated item that uses the aggregated items (which are successfully stored in the database) as inputs into the calculated item.
          zabbix version 1.8.6
          • Pada
            • Apr 2012
            • 236
            Have you managed to get it working yet.
            I've also had issues with a calculated item using aggregate items in its equation.
            There was 2 reasons why mine didn't work at first:
            1. I used grpsum[...] instead of last("grpsum[...]")
            2. I used keys within the grpsum function that didn't exist as aggregate items on that host
            So to get yours working, make sure that you've added aggregated items for:
            • grpsum["Mail Storage Hosts","mail.storage.used","last","0"]
            • grpsum["Mail Storage Hosts","mail.storage.total","last","0"]
            And then your calculated item should look like follow:
            100 * last("grpsum[\"Mail Storage Hosts\",\"mail.storage.used\",\"last\",\"0\"]") / last("grpsum[\"Mail Storage Hosts\",\"mail.storage.total\",\"last\",\"0\"]")
            Take note that I escaped the " within the grpsum function, and that I made use of the last() function with the grpsum as an argument for it.
            • nleaman
              • May 2010
              • 35
              ahh. I will try that.
