Hello, I'm trying to build Zabbix 1.8.9 from source on Ubuntu Server 11.10 64bit with Postgresql 9.1. My configure completed successfully and below is my configure arguments...
When I run make though I get into trouble. Below is what I see near the end. Any help would be greatly appreciated!
Kind regards,
Elvar
xcrypto/libzbxcrypto.a ../../src/libs/zbxcomms/libzbxcomms.a ../../src/libs/zbxcommshigh/libzbxcommshigh.a ../../src/libs/zbxjson/libzbxjson.a ../../src/libs/zbxexec/libzbxexec.a ../../src/libs/zbxself/libzbxself.a ../../src/libs/zbxserver/libzbxserver.a ../../src/libs/zbxicmpping/libzbxicmpping.a ../../src/libs/zbxdbhigh/libzbxdbhigh.a ../../src/libs/zbxdb/libzbxdb.a -lnetsnmp -lm -lresolv
../../src/libs/zbxdb/libzbxdb.a(db.o): In function `zbx_db_close':
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:443: undefined reference to `PQfinish'
../../src/libs/zbxdb/libzbxdb.a(db.o): In function `zbx_db_vexecute':
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:815: undefined reference to `PQexec'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:822: undefined reference to `PQresultStatus'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:824: undefined reference to `PQresultErrorMessage'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:824: undefined reference to `PQresultStatus'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:824: undefined reference to `PQresStatus'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:830: undefined reference to `PQstatus'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:836: undefined reference to `PQclear'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:834: undefined reference to `PQcmdTuples'
../../src/libs/zbxdb/libzbxdb.a(db.o): In function `zbx_db_fetch':
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:1273: undefined reference to `PQnfields'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:1283: undefined reference to `PQgetisnull'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:1289: undefined reference to `PQgetvalue'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:1290: undefined reference to `PQftype'
../../src/libs/zbxdb/libzbxdb.a(db.o): In function `PG_DBfree_result':
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:1388: undefined reference to `PQclear'
../../src/libs/zbxdb/libzbxdb.a(db.o): In function `zbx_db_vselect':
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:1119: undefined reference to `PQexec'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:1127: undefined reference to `PQresultStatus'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:1129: undefined reference to `PQresultErrorMessage'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:1129: undefined reference to `PQresultStatus'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:1129: undefined reference to `PQresStatus'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:1136: undefined reference to `PQstatus'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:1139: undefined reference to `PQntuples'
../../src/libs/zbxdb/libzbxdb.a(db.o): In function `zbx_db_connect':
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:293: undefined reference to `PQsetdbLogin'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:298: undefined reference to `PQstatus'
/root/download/zabbix-1.8.9/src/libs/zbxdb/db.c:300: undefined reference to `PQerrorMessage'
collect2: ld returned 1 exit status
make[3]: *** [zabbix_proxy] Error 1
make[3]: Leaving directory `/root/download/zabbix-1.8.9/src/zabbix_proxy'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/root/download/zabbix-1.8.9/src/zabbix_proxy'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/root/download/zabbix-1.8.9/src'
make: *** [all-recursive] Error 1
PHP Code:
./configure --host=x86_64-linux-gnu --build=x86_64-linux-gnu --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --enable-proxy --with-pgsql --enable-agent --with-net-snmp
Kind regards,
Elvar
