net.if 'unsupported' for ubuntu network interfaces
  • elvar
    • Feb 2008
    • 226
    While running Zabbix 1.8.5 and now 1.8.9 I'm unable to poll interface statistics from ubuntu servers that have zabbix agents on them. The items show up as unsupported. I'm using the stock "linux" template 'net.if.in[eth0,bytes]' for my item key. Does anyone know why or how to resolve this?
    Regards,
    Elvar
  • elvar
    • Feb 2008
    • 226
    PHP Code:
    27959:20111206:134204.646 Item [Server01:net.if.in[eth0,bytes]] error: Not supported by Zabbix Agent
     27959
    :20111206:134205.056 In substitute_simple_macros() data:'net.if.in[eth1,bytes]'
    27959:20111206:134205.056 In get_value() key:'net.if.in[eth1,bytes]'
    • elvar
      • Feb 2008
      • 226
      Interestingly enough, if I manually fetch the data I get a valid response.
      PHP Code:
       zabbix_agentd -t "net.if.in[eth1,bytes]"
      net.if.in[eth1,bytes]                         [u|145308058053]
      Any ideas on why the zabbix agentd process itself can't query this correctly?
      • elvar
        • Feb 2008
        • 226
        Solved
        It turns out that I had a NAT rule forwarding the zabbix connection to a windows server I was monitoring instead of the Ubuntu server I thought I was monitoring. It dawned on me when I noticed the wrong hostname in latest data. haha. That would explain the net.if issues.
        /newbsauce
