Trigger syntax help for packet loss please
  • elvar
    • Feb 2008
    • 226
    Hello, I'm trying to figure out the correct syntax to use with 'icmppingsec' so that if 5 or more out of the last 10 checks were > than X value then the trigger would be true. The reason I'm trying to do it this way is because I feel like this gets around the problem using the avg total response time where one really high sporadic check can cause a false alarm.
    Does this make sense?
    Thanks!
