Zabbix templates export on 1.9.8
  • mkein
    • Dec 2011
    Hello all,
    i would lilkt to share with you some bluecoat, fortinet (for versions 3.0 and 4.0), and checkpoint templates i managed to created. Im using them on the beta 1.9.8 but when i try to export them no items are exported, i managed to get the export using a frontend from the stable branch.
    If i upload them this way, will they be ok ? I mean exporting templates using the frontend from the previous release will create nonworking crap .. .-?
    Any ideas ?
    Thank you
    Javi
