Help!
  • eduardlh
    • Jan 2012
    Help!
    Greetings to all and thanks in advance to those who take the time to read this thread and also to help solve what I do
    Well what concerns me is the following, it is well known that if we are monitoring a service such as apache, when this is not available will be sent an alert, as we have defined it ... My question is ... Can I somehow detect that a service is trying to lift it down before sending the alert? ie for example, my apache stopped working before I could send the alert through a script on my zabbix agent running a script that does something like / etc/init.d/apache2 restart and if does not work then if you send ADMINISTRATOR the alarm .... If possible, as can be done?
  • simonseztech
    • Dec 2011
    Sure just check Escalation
    http://www.zabbix.com/documentation/...config/actions
    Enable escalations. If enabled, the action will be escalated according to operation steps defined for operations.
    More info here:
    http://www.zabbix.com/documentation/..._notifications
