Need to change data from "as is" to "speed per second"
  • linuxgurugamer
    • Oct 2010
    • 68
    I have a fairly large database, with about 75 million rows in the history table. I have a number of items which collect data once every 300 seconds. This throws our graphs off, and I want to convert the items to a "speed per second", while preserving the history.
    I need to update the history.value, trends.value_min, trends.value_avg, trends.value_max by dividing by the items.delay
    I will be selecting the items by the description:
    select itemid, delay from items where description like '%disk write%'
    This select will return 20-30 items, and each item’s history will need to be updated with it’s respective items.delay
    Has anyone done this yet? Is there a tool?
    While I can write the code, I'd rather use an existing, debugged tool.
    Thanks in advance.
    JBB
  • Yello
    • Apr 2011
    • 309
    No tool that I'm aware of. As I think you already suspect, you're gonna have to write and test the code yourself.
    Regards,
    David
