Zabbix Remote Commands + SMS send
  • pengu1n
    • Jun 2011
    Hello, all
    Here is a deal - I have a Zabbix server, Python installed and GSM modem - IRZ MC55iT connected via /dev/ttyS0 to my server. On Python I've wrote a script to generate SMS message and to deliver it to predefined address. So the thing is - can Zabbix run this script via Remote commands (on Zabbix server itself) and what do I need for it?
    As I understand, I will need zabbix agent installed (or not?), and sudo + write permissions on /dev/ttyS0, python script?
    Thx in advance.
  • HullZabbix
    • Feb 2011
    • 104
    I have Zabbix installed on CentOS, which has a USB GSM modem installed under /dev/ttyUSB0
    We have a bash script which takes in the parameters from zabbix when an alert needs to be sent.
    In zabbix itself, we have a media type defined as follows:
    Description: smssend
    Type: script
    Script Name: smssendscript.sh
    The bash script is located in /etc/zabbix/alertscripts/
    This location is defined in your zabbix server conf.
    Hope this helps.
    • pengu1n
      • Jun 2011
      It is simple
      Well, my bad. Zabbix can work with few GSM modems, plus IRZ MC55iT, which I have. So this info can be add to the Zabbix manual.
      All you need to do is:
      • Create necessary Media type -> SMS, name it and specify right device. In my case /dev/ttyS0
      • Add this media to necessary users with phone numbers - in my case starting with 8 + %PhoneNumber%
      • Give write access to necessary device for user, from which Zabbix is started. In my case - user: zabbix, console command:
      #>chown zabbix /dev/ttyS0
      #>chmod 0600 /dev/ttyS0
      So, that's all. After this Zabbix can send SMS successfully to the mentioned users, when necessary trigger will start a specified action.
      • HullZabbix
        • Feb 2011
        • 104
        That's good news. Our modem works like that but for some reason sends 3 x sms messages, so unfortunately we needed to go the external script route.
