Zabbix 1.8.10 Problem when removing Hosts from templates
  • saintxseiya
    • Oct 2010
    • 17
    i have a big problem with removing hosts from templates.
    Lets say the hosts are member of a template, if i am removing them, all the settings from the template will stay within the host settings, so all triggers etc.
    How do i remove from all hosts the not anymore needed TRiggers, Apps, Graphs etc.? Should they not be removed directly, by canceling the membership of the templatE?
    They remain as non-templated in the hosts.
  • Alwaysin
    • Jan 2012
    • 27
    when you go to the configuration page of the host : "Linked Templates", you select the template you want to remove, and you click "Unlink and clear".
    • saintxseiya
      • Oct 2010
      • 17
      Hi, yes i know thanks
      But what about all the already not templated linked stuff? i know i can filter for them, but is there a way to remove all the non template linked stuff from all hosts in a group?
      • sibinjosk
        • Dec 2014
        Work around to remove the data related to a deleted template
        Add the template again and use unlink and clear option to remove it again
