How to execute a command as a part of an item?
  • steve.enoch
    • Jan 2012
    I need to be able to kick off a process/command on a monitored host using zabbix, but it looks like zabbix only lets you do this using external checks which only kicks off a script on the server not on the host. I have seen that zabbix allows for you to kick execute a command on the host in a step, when a trigger is fired. It seems that I should be able to do this in an item as well.
    Is there a way to do this that I am missing or is there a standard work-around for this scenario?
    Thanks,
    Steve
  • JBo
    • Jan 2011
    • 310
    If you have zabbix agent on that host, you can use custom parameters to run a script to get an item value.
    Check the documentation for details.
    Regards,
    JBo
    • steve.enoch
      • Jan 2012
      Thanks JBo, this looks like what I was looking for!
      • trikke
        • Aug 2007
        • 140
        Assuming u have the agent on the host, you can as well use then system.run[<your command here>] key. You msut enable EnableRemoteCommands=1 in the agent configuration file, though!
        Greets
        Patrick
