Trigger history
  • linuxgurugamer
    • Oct 2010
    • 68
    Trigger history
    I am looking to have a trigger which will only go off no more than once an hour. Essentially, if it has been triggered anytime in the last 60 minutes, it shouldn't go off again.
    The trigger itself is a calculation, and would be hard to modify. Is there any way that I can easily see the last time the trigger went off, or if the trigger went off anytime in the past 3600 seconds?
    Thanks in advance.
    JBB
