Zabbix 1.9.9 API Host.create() trouble
  • sire
    • Jul 2010
    • 210
    Hi all,
    I am trying to create a host in 1.9.9 using Zabbix API, but it fails.
    Here is my JSON-RPC object:
    PHP Code:
    "params" : {
    "interfaces" : [
    "useip" : 1,
    "ip" : "10.1.2.3",
    "type" : 1,
    "port" : 10050
    "useip" : 1,
    "ip" : "10.1.2.3",
    "type" : 2,
    "port" : 161
    "groups" : [
    "groupid" : "11"
    "templates" : [
    "templateid" : "10049"
    "host" : "myhost1"
    "auth" : "f201fa9018f8f59fca8aea5577aab156",
    "jsonrpc" : "2.0",
    "method" : "host.create",
    "id" : 7
    I get the following error message:
    PHP Code:
    In create_host: Error: {"data":"Incorrect arguments passed to function","message":"Invalid params.","code":-32602}
    I have double checked that group and template ids do exist. I guess this might be a typo or brackets issue, but I can't find it.
    Host.create() call worked for me flawlessly in 1.8. I modified it for use with 1.9 according to this manual: http://www.zabbix.com/documentation/...pi/host/create
    Please, somebody help me
    I should have possible post this message to Zabbix Troubleshooting and Problems thread, sorry if I did it wrong.
    Regards,
    Sergey Syreskin
    Monitored hosts: 2646 / Active items: 23604 / Server performance: 765.74
    Temporary out of Zabbix business
  • sire
    • Jul 2010
    • 210
    Update:
    By debugging Zabbix API I have figured out, that fields "main" and "dns" are mandatory in the "interfaces" section. However, after adding the above fields to my JSON request, I get another error: "You do not have permission to perform this operation". The user, that connects to Zabbix API is a member of the "Zabbix administrators" group and is a Zabbix Super-Administrator, so the problem seems to be in permission check routines.
    Regards,
    Sergey Syreskin
    • sire
      • Jul 2010
      • 210
      IMHO this bug is caused by the https://support.zabbix.com/browse/ZBX-4615 issue.
      Regards,
      Sergey Syreskin
