Log monitoring
  • krimson
    • Sep 2008
    • 49
    Log monitoring
    I'm having serious trouble getting logfile monitoring to work, documentation on this is scarce and I am not sure how it is supposed to work.
    I have created an item (Zabbix active check). Type of information is set to Log. Log time format is empty.
    log["/path/to/logfile",,,]
    The logfile is readable to the zabbix user. Active checks are not disabled in the agent.
    I have enabled debugging and can see that it is processing the item, but Latest data does not show anything. I also created a trigger on this item but the trigger is in error state saying "Trigger was just added". And now it says "Zabbix was restarted".
    Zabbix 1.8.3.
    Any help is greatly appreciated.
