From zabbix API documentation:
Get methods output parameter
Output can be “shorten”, “refer”, “extend” and array of db field names.
-shorten: only ids of elements are returned. (for hosts it's hostid, for items itemid etc)
-refer: element ids are returned with element ids that were used in query.
For example request item.get(output: refer, hostids: [1,2,3])) will return items with itemids and hostids.
-extend: all db fields of element are returned (select *)
-array of db fields: listed db fields are returned
What is the correct format to pass an array of db fields? I have tried the following:
but this only returns the itemids
or is there a different way to filter the returned fields?
"id":"1",
"method":"item.get",
"params":
"search":{"description":"Comp."},
"seachWildcardsEnabled":"1",
"output":["lastvalue","lastclock","host"]
"jsonrpc":"2.0",
"auth":"045fe742cf405bb83281bff2567b1eef"
"jsonrpc":"2.0",
"result":[
{"itemid":"22319"},
{"itemid":"22318"},
{"itemid":"22328"},
{"itemid":"22330"},
{"itemid":"22332"},
{"itemid":"22334"},
{"itemid":"22336"},
{"itemid":"22338"},
{"itemid":"22324"},
{"itemid":"22326"},
{"itemid":"22325"},
{"itemid":"22327"},
{"itemid":"22329"},
{"itemid":"22331"},
{"itemid":"22333"},
{"itemid":"22335"},
{"itemid":"22337"},
{"itemid":"22339"}],
"id":"1"
